Hi folks so I acquired my son's gaming headset after the lead failed yet again. So instead of consigning to the bin, I have decided to replace the lead with a plugged lead. Anyway, everything went well, and I ended up with a headset that works quite well, exept I was not terribly happy with the microphone. Levels are rather low and while windows recognises for voice commands and do not think it is good enough for talking to poeple.
Now if you look at the picture I have posted, one thing that occurred to me straight away, was that the built-in mic, being a tiny electret type, had no power supply. I wondered if my son's ps3 controller perhaps provides a voltage?
What I am fairly sure about, is that despite telling the soundcard I have plugged in a mic, it doesn't provide a supply. This means the output must be tiny and might explain why results are not sensitive.
Soo, I knock up a standard mic circuit and plug it in...
And here lies the problem. Powered up, output is mute. Powered off and it is like I haven't done the mod. On writing this I do wonder if the mic is being saturated and I should try a higher resistor?
Any ideas would be appreciated!
Thank you!
p.S. I just want to add circuit has been checked, the pins have got to be correct otherwise I would either get an echo sound from speakers (ground pin wrong) and no mic or mic and good sound and I have the latter.
Thank you!
