It is incorrect because 4*8bit doesnt give you enough bits for the 64bit data path.
The 16x (256Mbx16Bit) could work if the memories are capable of paralleling their outputs together, because you would need 4 sets of 4 chips with their outputs in parallel and one of those four would be active at a time, which gives you 64 bits on output and a choice of four different memory sets.
So 4x(1024MBx16) is correct then?
4*1024=4096 and 4*16=64.
