Hello, I'm not sure how to go about measuring the voltages and current of the B/C/E of the transistor. Here is the circuit that I was tasked to create:
and here is the circuit i created in multisim:
9v was used as the VS because the task specified to use 5v+n n being a single digit number.
I need to measure
a) base voltage, Vb
b) emitter voltage, Ve
c) collector voltage, Vc
d) total current, It
e) base current, Ib
f) collector current, Ic
g) static current gain, hfe
I'd like to do it with the meter if possible so I can know how to use a meter in real life if i need to.
I need to measure
a) base voltage, Vb
e) base current, Ib
