MCU and negative voltage signal
andrea.rafg91
Joined Jul 22, 2017
I have a MCU with +3.3V output pins, I will need to power down a device which expects -3.3V signal (it takes no more than 0.5mA current from this signal, it only expectes the negative voltage level).
How could I accomplish this? should I use a P-channel MOSFET, N-Channel? JFET? do you have a recommendation for a +3.3V logic level transistor?
Thank you very much in advance!
Andrea
AlbertHall
Joined Jun 4, 2014
12,626
The circuit below assumes that a 10k resistor to -3.3V will activate the power down signal. Note that the power down signal will be activated when the MCU output is low which is the reverse of your circuit.
andrea.rafg91
Joined Jul 22, 2017
Thank you for such fast answers. So I understand I should use n-Mosfet or BJT. Thank you AlbertHall for your schematic, the simulation looks good.
Another issue I have is that I should reduce to the minimum the power consumption. How ist it BJT vs N-Mosfet? which one would be better for power efficiency?
Thank you very much again for your help.
Andrea
