Are there any of these online calculators that use the external transistor?You could try using the chip output to short the base current for the external transistor, supplied by a resistor from Vcc.
If I use transistors correctly, or install them into my tester, the C/E voltage is close to 0V, not 0.7V, that is a wrong value.
Also simulation software might be of use to you, LTSpice etc.
To test various way of driving transistors at this voltage (3V).
So what I suggest is actually called "external saturated switch" in the manual. Maybe also can be used for NPN.
i want to use a FET just because I have a big bag of them. I got it working but would like to optimize it as best I can. i'm making a step up to 200+ volts.
