- Joined Jul 18, 2013
- 30,810
The one I have shows R50 marked 103 (10K.)
Yess I tried it and i changed it as well.Did you try adjusting the preset speed pot on the main board?
I want to replace D1 and D8. I have no clue what name part to search for. Shall i take them out and then post pics or numbers written on them? Or you can tell me without taking them out. I am good in soldering but not a proper technician.@MaxHeadRoom
Hi you are the best and very helpful. I seen your reply from 2012 till now you helping people. I am nil and have no clue about schematics and readings, i have Mc2100els-18w board. Can you please check #245 post and let me know in easy language please. D1 diode is short and STR is heating up. Where can i buy D1. What readings i have to look in to. Will appreciate your help. Thanks
They are short, i checked with multimeter. D4 reading is fine but D1 is beeping , same D8 is beeping.What is the reason you want to replace them ? They look fine, If in doubt, I would remove them and test them out of circuit.
Both directions, I presume?They are short, i checked with multimeter. D4 reading is fine but D1 is beeping , same D8 is beeping.
Hello,Hello everyone! I bought a faulty Domyos TC-5 treadmill (220VAC European version), which has the same controller unit (U-MC2100ELS-18w), and a 130VDC, 2.8hp, 1939W motor. The board and the motor were faulty too. On the board I need to replaced the IGBT and the Q3 thyristor also. The board is OK now, but I only had a 180VDC 2hp replacement motor for the treadmill. After reassembly I try out the speed calibration, but due to the 180VDC motor, the treadmill only goes 11.2KM/h insted of 16KM/h (the max speed potentiometer was on the max setting). There is any hack to use this contoller board with an 180VDC motor, or I need to find a 130VDC version. I have the attached menu options in the service menu, maybe it helps a little. Thanks for your help! Regards, István
Thanks to whoever posted the schematic. I had an issue with a similar board MC5100DTS-50W (Nordic Track X9i) and it was helpful to diagnose a problem. Everything on the treadmill worked except the motor wouldn't run. It turned out that L1 was damaged (open circuit). On the MC5100DTS it doesn't use the 10V zener (D8) to generate the lower voltage DC signal. It uses a switching circuit that L1 is a part of.
Also one of the 1000uF 200V capacitors was swollen so I'm replacing that as well.
The member posted only once in 2018. It is very unlikely that we will hear from him again.I know it's quite a long time since your post, but do you have the value of L1 on a MC5100-50 w ? Mine is damaged and I can't find any information on it.
Thanks
Do you have a screen shot of the device and/or board?I know it's quite a long time since your post, but do you have the value of L1 on a MC5100-50 w ? Mine is damaged and I can't find any information on it.
Thanks
Here is the picture of the board with the L1 just on left side of the U13.The member posted only once in 2018. It is very unlikely that we will hear from him again.
Where is L1 on your board?
On other boards, L1, 5.5 mH is in series with the motor.
Yes I still use the console.Where are you supplying the PWM from, the TM console? or an external source?
Does the controller IC have the correct power?
