MaxHeadRoom
- Joined Jul 18, 2013
- 30,881
What is the exact MC2100-? part No on your board?
Hi Famu - I have the same problem, I'm about to replace R24 with a 0.56 ohm 5W. Did you do more than replace? Successful? Thanks... Paul (Canada)Hello,
Bad luck for me
I found the first hs resistor that I had changed for the first breakdown. It was indeed a 0.56 ohm but in 2w. For me, for it to burn, it must be shorted through the capacitor or through the transformer. What other reason could there be?
Thank you for your help![]()
Hi Famu - I have the same problem, I'm about to replace R24 with a 0.56 ohm 5W. Did you do more than replace? Did this get the readmill going? Thanks... Paul (Canada)Hello,
Bad luck for me
What does the LED show? Any change?
MC2100 is normally a 20Hz pulse?
| Thread starter | Similar threads | Forum | Replies | Date |
MC2100ELS treadmill repair (3) | Technical Repair | 16 | |
| C | MC2100ELS-18W treadmill motor control circuit | Technical Repair | 3 | |
| M | MC2100 treadmill motor control circuit #4 | Technical Repair | 10 | |
| D | MC2100 Rev 2 treadmill - home circuit breaker blows | Technical Repair | 10 | |
MC2100ELS-50W Treadmill Controller | Technical Repair | 7 |
