MC2100 treadmill motor control circuit
Я приложил новую версию списка компонентов и исправил чертежный лист 2.
[/ QUOTE]
всем привет, помогите пожалуйста .... На моей плате mc2100els-18w сгорела микросхема (CY8C24223A-24PVXI) .... какие варианты исправить, где найти прошивкуView attachment 20201230_235222.jpg
hello everyone, please help .... On my mc2100els-18w board, a microcircuit (CY8C24223A-24PVXI) burned out .... what options to fix, where to find the firmware
heating occurs immediately after plugging into the network, the board immediately begins to heat up, I connect only the power supply from the network, the other connectors are free ... on 20 and 10 legs 5 volts, while the LED is constantly on red
Hi guy's I've one of these boards in my treadmill. The problem I have is the treadmill has no power what so ever. Doing some basic diag I get a flicker of the led and 9v at the interconnects to the display. The 9v only stays on for a few seconds. For those with more experience does the led stay lit and do you get stable 5v and 9v outputs
Thanks Steve
MaxHeadRoom
Joined Jul 18, 2013
30,886
Where are you measuring?
The LED normally comes on permanent 1 sec after switch on, when a track command is issued, it should flash slowly at a constant rate.
On HD2 you should have 12v to 15vdc between 1 & 2. and 5vdc on pins 10 & 20 of the micro processor.
Max.
Thanks Max, I've taken the board out of the treadmill so there's nothing attached. Measuring at HD2 pins 1 gnd and pin 2 I briefly get 9v. On the processor only getting 1.2v between pins 10 and 20. The led is not lit. I'm assuming I must have either a short been generated or the feedback to the regulator isnt right. Anyone seen this before
MaxHeadRoom
Joined Jul 18, 2013
30,886
The source of the HD2 pin voltages vary with model, they all are LV transformer secondary based, some have the TFMR off-board.
Carfully measure the input and output of the bridge rectifier on the end of the heat sink.
The DC should be around 107VDC.
Just to the right of the HD2 socket there should either be 4 or 2 rectifier diodes, depending on whether it has the LV bridge or the CT transformer type.
Max.
robeegida
Joined Feb 6, 2021
[QUOTE = "Bhen1374, post: 1530699, címke: 715146"]
Pls segítsen nekem, van nordictrack, nem működik a motor, amikor megnyomom a start választ, a LED villogott 8-szor, majd egy másodperc alatt kikapcsol, majd újra 8-szor villog és így tovább
mc2100els 18w fedélzeti motorvezérlő
[/ IDÉZET]
Szia. mi volt a gond? megjavították? have the same problem
gopakumar
Joined Mar 14, 2021
9
i have a proform treadmill wich uses MC2100ELS-18W board. While running the motor suddenly achieved a full speed and the breaker switch turns off. When checked, i found the MOSFET faulty. Replaced it. But when ever power is given the mosfet immediately blows off and motor runs at full speed and the breaker switch turns off. Again i examined and found two 200 ohm resistors at the gate of MOSFET were also blown. But changing them along with MOSFET doesn't help. While powered, the same happened. Please help.
One mistake in the posting. The burned out part was G4PC40K which is an INSULATED GATE BIPOLAR TRANSISTOR
MaxHeadRoom
Joined Jul 18, 2013
30,886
Try using a smaller load than the motor, lamp etc, and check to see if the DC voltage ramps up when a command is issued, if it comes up to full voltage immediately, suspect the SCR.
Chpa17
Joined Mar 26, 2021
14
Hi all,
I have a main board to repare, it’s mc2100ELS-18-2y REV-
I tested the circuit in my table , just connected with the power cord, 230V .
the led lights up strongly at the start then decreases in intensity and remains lit weakly, there is 5V and the 9v and after a few seconds, the voltages drop to less than 1V, do you have any idea of the failure?
thanks you
Chpa17
Joined Mar 26, 2021
14
Thanks you , I Check Q7 and it is Broken .It’s a smd code 2T , it’s KST4403 transistor , it’s ok?
