MC14035BC shift register
GeorgeEng
Joined Nov 20, 2016
14
Hello Everyone !!!
I am trying to make the parallel in parallel out shift register MC14035BC working as a parallel in serial out register. Does anyone has experience on that circuit ?? I have searched all the internet and I haven't find sufficient information neither the datasheet says something similar . Does anyone has application schematics on that circuit ??
Thank you very much.
George
dl324
Joined Mar 30, 2015
18,524
I do not mind about the direction but I would like to know how and if you can switch it's direction
Shift right is easy.
After parallel loading, a LOW on P/S# will shift right; output is from Q3. You need to take the output from Q3 before you begin clocking for shifting. After 3 clocks, serial data will be taken from the J/K# inputs.
EDIT: Data from the serial input starts entering the shift register on the first clock.
Shift left is more work.
You need to feed the outputs Q3-Q1 to the corresponding parallel input for the previous flip flop DP2-DP0. Output is taken from Q0 and serial input is from DP3. Shifting left requires setting P/S# to HIGH; so some multiplexing with the existing parallel input data circuitry is needed.
EDIT: changed DP3-DP0 above to be DP2-DP0.
For parallel load with bi-directional shift, MC14194 would be more convenient.
GeorgeEng
Joined Nov 20, 2016
14
Thank you but it my circuit doesn't seems to work....... I send you a picture of what I have done so that you can tell me what I have done wrong. The upper button is the clock and the the other the reset . The circuit is in complementary and parallel mode. And I have put a "1" to the PI1
Thank you very much
George
dl324
Joined Mar 30, 2015
18,524
Could you post a schematic? I don't have the patience to trace breadboards if they're not mine.
What do you expect the circuit to do and what is it doing?
GeorgeEng
Joined Nov 20, 2016
14
I expect to take that input which is 0010 and shift the compliment in parallel and then by switching to serial , to shift those values serially........ In few words I struggle to make a parallel to serial shift register........
I post you a schematic which I made in paper brevity.
Regards
George
dl324
Joined Mar 30, 2015
18,524
You have a lot of floating inputs; they need to be tied HIGH or LOW.
Reset is HIGH, so the shift register is always reset.
T/C# is HIGH, so you won't get complemented output.
dl324
Joined Mar 30, 2015
18,524
This is what you should have:
The simulator I used doesn't have resistors, so I used switches. The LEDs are strange in that they don't need a connection to ground. The switches are strange in that when opened, they provide a LOW.
The dark nets are logic HIGH, gray are logic LOW.
It also didn't have a CD4035/MC14035, so I had to create it.
dl324
Joined Mar 30, 2015
18,524
Low means putting the input to the ground ???
Yes; using a switch, resistor, another gate, transistor, etc.
I just noticed that the dots in your schematic are the switches. So the shift register can function when its switch is opened.
