Just stumbled on a motor and controller from a Reebok RX1000 treadmill (c. 2000). Motor is fine. The board is a MC-2000 Rev B; it is divided in two boards. See attached image and schematic pdf. It seems to require a PWM speed signal; not having the original console, I attached a PWM signal generator (as I have done with MC-2100 boards). Currently, the board LEDs light up as follows when powered: On right board, 120Vac, +9V, +5V, and flashing PWM (when signal is on); on left board, 15V (LD1), but not the green HV BUSS (LD3), GATE (LD4), and SPD SIG(LD2). Needless to say, it does not currently send power to the motor leads.
Question: does anyone know the required PWM frequency for this board (I've tried 20Hz as per MC-2100). Of course, the 20Hz could be correct but the board is broken somewhere (I suspect likely). I'm a Newbie, but perhaps the symptoms indicate a likely fault to someone more experienced. Would appreciate any suggestions. Thanks.
