Keithley2000 restored
panic mode
Joined Oct 10, 2011
5,450
I have a old Keithley2000 that was has seen better days. while it works nicely, it did not have power button (push rod missing in action) and the amp socket was missing along with fuse.
i really like working with it so i finally decided to do something about it and get it calibrated (sticker says this was not done in a while).
this is what that missing amp socket / fuse holder looks like, it is white and has two prongs so one can twist it to access fuse behind it. obviously on unit i had this was removed forcibly so little ridges that are supposed to hold the jack in place are gone.
that means even if the replacement part was found, it could not be used without also finding replacement front panel.
powered it down, opened it up, measured distance between switch and front panel then sketched 3D model, printed it and to my surprise - it worked on first try. the white amp socket/ fuse holder seem o be unobtanium so instead of one hard to find part, i used two low cost standard parts.
all that was needed is to drill hole for the fuse holder and ad one wire. original wire was thin, teflon jacket. end inside Amp socket was spring loaded so i pulled it as much as spring allowed, then cut it. this comfortably reaches fuse holder in the back.
then new shrouded jack was installed. it was one of the last few in my drawer and yes, it was a black one (CT4397-05-0) but who cares, i was not going to wait 2 days. the fuse is 3A fast blow per service manual.
this is insides before surgery:
and this is after surgery...
new jack just fitted in. to keep it centered, i moved the nut fully on. to adjust how deep it sits, i added small plastic washer as a spacer (3mm) at the back. then soldered wire to it, applied a bit of glue and pressed it in. done...
Nice work! A 3D printed push rod that fits on the first try is the best kind of surprise. And honestly a black jack on a 2000 has a bit of character, nobody will mistake it for factory but it does the job just as well.
Good call getting it calibrated too, it's a meter worth keeping alive.
