MC-02 Treadmill Controller
30,740
There is quite a few videos on youtube for method of testing to see the switching action.
Mouser or Digikey stock them, among others.
Davrowbf
Joined Feb 15, 2025
75
Sayal Electronics - free shipping with order over C$50.
S6015L SCR 600V 15A https://secure.sayal.com/STORE4/prodetails.php?SKU=167838
Q4008R4 TRIAC 400V 8A https://secure.sayal.com/STORE4/prodetails.php?SKU=142156
I am not sure if a TRIAC will also work in this application.
I can pick one up and send it by post to you.
Note that the MC-02 treadmill controller is not recommended for high power applications.
Thanks MrChips I know the value of the MC-02 as you refer and a follower of the youtube channel you highlight. It is not my intent to spent a lot of money to repair this board but to increase my knowledge in; how to repair, things to look for and soldering skills in board repair. At this juncture in life it is something to keep the mind active. I have already learned a great deal thanks to you guys. Thanks for the offer to mail a replacement but that wouldn't be necessary. I have access to the following; K30502-01, MBR30100-DT and BT138-600E maybe you could tell me if either of these are close?? It is more about making it work than being able to use it. I may find a suitable replacement from China, cheep and free shipping
Davrowbf
Joined Feb 15, 2025
75
Amazon has the BTA12-600 10Pc for $11.00 + tax, free shipping. Any good?
34,980
10pc for $11, you can't beat that.
BTA12-600 is a TRIAC.
A TRIAC is bidirectional where as an SCR is unidirectional. I don't know if this will work without seeing the schematics.
If the two TRIACs are in a bridge circuit then they will likely blow by shorting across the power supply.
Davrowbf
Joined Feb 15, 2025
75
If that is two SCR's then it is using the same method as the MC-60 board where the SCR's are part of a full wave bridge, there are two large diodes that complete the briodge.
D9 - D10 ?
If D9 and D10 are a part of the bridge are they also uni-directional? on D10 I get a reading one way of .478v the other way 3v whereas on D9 i get 0v and .5v. D8 is reading the same as D10 on the diode scale
