I was just needing to know whats the peak frequency down a usb wire? Just guessing... 3ghz?
Thread Starter ranch vermin Joined May 20, 2015 85 Sep 20, 2015 #1 I was just needing to know whats the peak frequency down a usb wire? Just guessing... 3ghz?
shteii01 Joined Feb 19, 2010 4,644 Sep 20, 2015 #2 Depends on bitrate. 1.5 Mbits/s is the lowest. 10000 Mbits/s is the highest.
Papabravo Joined Feb 24, 2006 22,083 Sep 20, 2015 #3 Check out the USB Wiki https://en.wikipedia.org/wiki/USB
MaxHeadRoom Joined Jul 18, 2013 30,671 Sep 20, 2015 #4 USB3 is rated now for up to 5gbs (640MBps) but has been found in practice to be quite a bit lower, but still quite a bit higher than USB2. Max.
Thread Starter ranch vermin Joined May 20, 2015 85 Sep 21, 2015 #5 I see - its not the "frequency" its the bitrate, thankyou.
