matching microstrip calculator with formula theory question
yef smith
Joined Aug 2, 2020
1,481
Hello, i have a microstrip operating at 10GHz L=4.91mm Er=9.6 d=0.254mm W=0.24mm as shown bellow.
from transmission line theory
Ee=0.5*(9.6+1)+0.5*(9.6-1)*(1/sqrt(1+12*(0.254/0.24)))=6.46mm
W/d=0.94
Z0=49.77 from formula (3.196)
k0=209.4[1/m]
phi=sqrt(6.46)*209.4*4.91*10^(-3)=2.61[rad]=149.8[deg] as shown bellow.
I want to convert my 150 degrees into wavelength.
Is there a manual where i can find how many wavelength there are in the 150 degrees?
Thanks.
ZCochran98
Joined Jul 24, 2018
356
The electrical length of your microstrip (L=4.91mm) corresponds to, according to ADS' LineCalc tool, for your substrate, a 150-degree line, or 0.417 wavelengths (150degree/360 degree = 0.417*lambda).
Where this comes from is this: at 10 GHz, the wavelength of a signal is 30 mm in air (300*10^8 m/s/10 GHz -> 3/100 m or 30 mm [3cm]). However, in a substrate that is further reduced by a factor of \(\sqrt{\epsilon_r}\), so the wavelength at 10 GHz in your substrate is 30 mm / sqrt(9.6) = 30/3.098, which is roughly 10 mm (9.68mm). So a 4.91 mm line is approximately 4.91/10 of a wavelength, or, precisely, 0.417 wavelengths.
Now, the estimate using \(\sqrt{\epsilon_r}\) assumes the entire wave is inside the substrate. For a microstrip, some of the electric field is in the air, so you'd have to use the effective permittivity (which is probably closer to roughly 6.5ish based on a back-of-the-napkin estimate without looking at your W/d ratio - that's \(\epsilon_e\) in your equations), which gives a wavelength of 11.8 mm, so, using that, 4.91 mm is about 0.416 of a wavelength (which is really close to ADS' predicted 0.417).
So, in other words, the degrees ADS gives you can be converted to fractions of a wavelength (electrical length/360 degrees), and wavelength can be found by \(\lambda = \frac{c}{f\sqrt{\epsilon_e}}\).
Hope this helps!
