matching LC filter
yef smith
Joined Aug 2, 2020
1,459
Hello , i have designed a basiclow pass filter circuit using next i want to match it to the input and output
Z=sqrt(L/C) =0.707ohm
so i put 0.707Ohm on the output to match it.
so there are no ringing overshoot but i get a -6dB value at the output.
In filter design i need to have 0dB output.
Is there a way to get 0dB responce?
Thanks.
yef smith
Joined Aug 2, 2020
1,459
UPDATE:
When I removed the input resistor i get 0dB on the output.
What is the logic of reflection coefficients which does with one resistor 0dB on the output but when i put on both sides i get -6dBV output.
Thanks.
yef smith
Joined Aug 2, 2020
1,459
Hello crutchow, so if i have a signal generator Agylent 33220A signal generator.
What is the series resistor i should use?
Thansk.
eetech00
Joined Jun 8, 2013
4,705
yef smith
Joined Aug 2, 2020
1,459
Hello , so I need to match 50 ohm LC ladder to 200k :)
Is there a way to do an LC transformer ?
How do I know that the LC section is “quarter wavelength “
Phase of 90 degrees.
Also it’s impedance needs to be sqrt(50*100k)
1.
how can I know at what frequency to design my transformer given The rise tiMe
2.how can I know the phase of the section is lambda/4 ?
Thanks .
