MASTER and SLAVE PICs using SPI in Oshonsoft
camerart
Joined Feb 25, 2013
3,847
Hi C,
Show your QEI code for slave.
Hi J2,
SLAVE at #45
As mentioned, Oshonsoft doesn't support QEI in the simulator, but I can try in circuit live, as I am doing with all of the above.
I don't have a Schematic for the SLAVE yet, as I want to get the software to work first.
The SLAVE PC is on a breakout board where I connect the PINs as needed.
C.
jayanthd
Joined Jul 4, 2015
945
Hi C,
Please provide your QEI setup and reading code. I will add it to SPI communication code and test it and send it to you. I just need to know QEI registers configuration and how to get value in CAP2BUFH:CAP2BUFL.
Are you using CAP2 or CAP1 that is QEI2 or 1 ?
jayanthd
Joined Jul 4, 2015
945
Hi C,
Just show the code for QEI to read quadrature encoder. I just want to get some value in CAP2BUFL register which I can send to master. My SPI communication is working fine.
I have Quadrature Encoder model in Proteus and I can quickly test the code and after get QEI code working I can send you the code for testing.
I don't want to know your Compass reading code. I just want to get some value in CAP2BUFL register using QEI module.
jayanthd
Joined Jul 4, 2015
945
Hi C,
I got the QEI module working. I am getting values in CAP2BUFL and also master is receiving it and displaying it on its PORTB. I will post the files soon. I have to make simulation video.
Edit:
Here is the simulation of video. I have used OshonSoft PIC18 Basic Compiler to write the codes.
camerart
Joined Feb 25, 2013
3,847
Hi C,
Hi J2,
The program in #4 is complete, I have tried variations e,g, SSPBUF = CAP2BUFL.
CAP2BUFL and CAP2BUFH are qualities of the 18F4431 PIC.
The QEI is automatic, and if PINS 22 and 23 are pushed in the QUADRATURE SEQUENCE, then CAP2BUFL and CAP2BUFH count up to the set number.
When set to SSPBUF = CAP2BUFL. and, as mentioned Hserout "#SSPBUF = ", #SSPBUF, CrLf is added, then I can see the result on a computer terminal.
C.
jayanthd
Joined Jul 4, 2015
945
Here are the latest working OshonSoft PIC18 Basic Compiler codes to send slave's CAP2BUFL register data to master's PORTB using hardware SPI.
Continuous Quadrature Encoder data reception from slave.
OshonSoft PIC18 Simulator IDE's Basic Compiler / OshonSoft PIC18 Basic Compiler codes follows.
SPI-Master - PIC18F4620 @ 8 MHz HS
Code:
AllDigital
Symbol spi_cs = PORTA.5
Symbol spi_cs_direction = TRISA.5
Symbol button = PORTD.0
Dim x As Byte
    x = 1
    initialize_ports
    initialize_spi_master
    enable_interrupts
    While x > 0
        send_spi_data 0xff
        initialize_spi_slave
        WaitMs 300
    Wend
End
On Low Interrupt
    If PIR1.SSPIF Then
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            LATB = SSPBUF
        Endif
    Endif
    SSPCON1.SSPOV = 0
Resume
Proc initialize_ports()
    CMCON = 0x07
    ADCON1 = 0x0f
    TRISA = 0xc0
    TRISB = 0x00
    TRISD = 0x01
End Proc
Proc initialize_spi_master()
    TRISC = 0x10
    spi_cs_direction = 0
    spi_cs = 1
    SSPSTAT = 0x40
    SSPCON1 = 0x22
    IPR1.SSPIP = 0
    PIE1.SSPIE = 0
End Proc
Proc initialize_spi_slave()
    TRISC = 0x18
    spi_cs_direction = 1
    SSPSTAT = 0x40
    SSPCON1 = 0x24
    PIE1.SSPIE = 1
End Proc
Proc enable_interrupts()
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
Proc send_spi_data(data As Byte)
    spi_cs = 0
        SSPBUF = data
        While SSPSTAT.BF = 0
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
SPI-Slave - PIC18F4431 @ 8 MHz HS
Code:
AllDigital
Dim data As Byte
Dim spidatareceived As Bit
Dim x As Byte
Dim counter As Byte
Symbol spi_cs = LATC.6
Symbol spi_cs_direction = TRISC.6
    initialize_ports
    initialize_variables
    initialize_qei
    enable_interrupts
    While x > 0
        If spidatareceived = 1 Then
            send_spi_data CAP2BUFL
            LATD = CAP2BUFL
            spidatareceived = 0
        Endif
    Wend
End
On Low Interrupt
    If PIE1.SSPIE = 1 And PIR1.SSPIF = 1 Then
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            data = SSPBUF
            If data = 0xff Then
                spidatareceived = 1
            Endif
            data = 0
        Endif
        SSPCON.SSPOV = 0
    Endif
Resume
    ANSEL0 = 0x00
    ANSEL1 = 0x00
    TRISA = 0xdc
    TRISB = 0x00
    TRISD = 0x00
End Proc
Proc initialize_variables()
    x = 1
    spidatareceived = 0
End Proc
    PIE1.SSPIE = 0
    TRISC = 0x14
    spi_cs = 1
    SSPSTAT = 0x40
    SSPCON = 0x22
End Proc
    SSPSTAT = 0x40
    SSPCON = 0x24
    TRISC = 0x74
    IPR1.SSPIP = 0
    PIE1.SSPIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
Proc initialize_qei()
    POSCNTH = 0x00
    POSCNTL = 0x00
    QEICON = 0b10000000
    QEICON = 0b10010100
    DFLTCON = 0x00
    MAXCNTH = 0x04
    MAXCNTL = 0x00
End Proc
camerart
Joined Feb 25, 2013
3,847
Code:
AllDigital
Dim x As Byte
    x = 1
    initialize_ports
    enable_interrupts
    While x > 0
        send_spi_data 0xff
        WaitMs 300
    Wend
End
On Low Interrupt
    If PIR1.SSPIF Then
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            LATB = SSPBUF
        Endif
    Endif
    SSPCON1.SSPOV = 0
Resume
    CMCON = 0x07
    ADCON1 = 0x0f
    TRISA = 0xc0
    TRISB = 0x00
    TRISD = 0x01
End Proc
    TRISC = 0x10
    spi_cs = 1
    SSPSTAT = 0x40
    SSPCON1 = 0x22
    IPR1.SSPIP = 0
    PIE1.SSPIE = 0
End Proc
    TRISC = 0x18
    SSPSTAT = 0x40
    SSPCON1 = 0x24
    PIE1.SSPIE = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
Code:
AllDigital
Dim data As Byte
Dim x As Byte
Dim counter As Byte
    initialize_ports
    initialize_qei
    enable_interrupts
    While x > 0
            LATD = CAP2BUFL
            spidatareceived = 0
        Endif
    Wend
End
On Low Interrupt
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            data = SSPBUF
            If data = 0xff Then
                spidatareceived = 1
            Endif
            data = 0
        Endif
        SSPCON.SSPOV = 0
    Endif
Resume
    ANSEL0 = 0x00
    ANSEL1 = 0x00
    TRISA = 0xdc
    TRISB = 0x00
    TRISD = 0x00
End Proc
    x = 1
    spidatareceived = 0
End Proc
    PIE1.SSPIE = 0
    TRISC = 0x14
    spi_cs = 1
    SSPSTAT = 0x40
    SSPCON = 0x22
End Proc
    SSPSTAT = 0x40
    SSPCON = 0x24
    TRISC = 0x74
    IPR1.SSPIP = 0
    PIE1.SSPIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
    POSCNTH = 0x00
    POSCNTL = 0x00
    QEICON = 0b10000000
    QEICON = 0b10010100
    DFLTCON = 0x00
    MAXCNTH = 0x04
    MAXCNTL = 0x00
End Proc
Hi J2,
When I try to open the video, I get Arduino opening, or nothing. I believe it's working, and I'm looking at your programs.
The MASTER program shows errors when compiling in Oshonsoft. 'Incorrect proc names'
For clarity I like to see '%XXXXXXXX' instead of HEX 'XxXX', I can change them or is it easy for you?
I don't have a BUTTON on the SLAVE breakout board, do I need one to test your programs?
C.
jayanthd
Joined Jul 4, 2015
945
Hi J2,
C.
Consider only code of post 108 and its circuit. Video file opens in Windows media player or VLC player.
I will change code and send it to you so that it uses %01010101 syntax.
You need 3 pins from the QE i.e., QEA, QEB and INDX and 8x Leds on PORTB of master and 8x Leds on PORTD of slave. In Proteus I have used Logic Probes on these ports.
Here are the codes.
I didn't test them in PIC18 Simulator IDE's Basic Compiler.
OshonSoft OshonSoft PIC18 Basic Compiler codes follows.
Code:
AllDigital
Dim x As Byte
    initialize_ports
    enable_interrupts
    While x > 0
        send_spi_data 0xff
        WaitMs 200
    Wend
End
On Low Interrupt
    If PIR1.SSPIF Then
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            LATB = SSPBUF
        Endif
    Endif
    SSPCON1.SSPOV = 0
Resume
    x = 1
End Proc
    CMCON = %00000111
    ADCON1 = %00001111
    TRISA = %11000000
    TRISB = 0
    TRISD = 0
End Proc
    TRISC = %00010000
    spi_cs = 1
    SSPSTAT = %01000000
    SSPCON1 = %00100010
    IPR1.SSPIP = 0
    PIE1.SSPIE = 0
End Proc
    TRISC = %00011000
    SSPSTAT = %01000000
    SSPCON1 = %00100100
    PIE1.SSPIE = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
Code:
AllDigital
Dim data As Byte
Dim x As Byte
    initialize_ports
    initialize_qei
    enable_interrupts
    While x > 0
            LATD = CAP2BUFL
            spidatareceived = 0
        Endif
    Wend
End
On Low Interrupt
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            data = SSPBUF
            If data = 0xff Then
                spidatareceived = 1
            Endif
            data = 0
        Endif
        SSPCON.SSPOV = 0
    Endif
Resume
    ANSEL0 = 0
    ANSEL1 = 0
    TRISA = %11011100
    TRISB = 0
    TRISD = 0
End Proc
    x = 1
    spidatareceived = 0
End Proc
    PIE1.SSPIE = 0
    TRISC = %00010100
    spi_cs = 1
    SSPSTAT = %01000000
    SSPCON = %00100010
End Proc
    SSPSTAT = %01000000
    SSPCON = %00100100
    TRISC = %01110100
    IPR1.SSPIP = 0
    PIE1.SSPIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
    POSCNTH = 0
    POSCNTL = 0
    QEICON = %10000000
    QEICON = %10010100
    DFLTCON = 0
    MAXCNTH = %00000100
    MAXCNTL = 0
End Proc
Edit2:
Oops, Sorry.
I used PIC18 Simulator IDE's Basic Compiler only. I didn't use OshonSoft's PIC18 Basic Compiler.
jayanthd
Joined Jul 4, 2015
945
I compiled the codes successfully in both OshonSoft's
PIC18 Simulator IDE's Basic Compiler and
and they compile fine.
Here is the project attached.
If .bas file gives error then open .bas file in notepad and copy code and paste it in Compiler and try to Compile.
Here is a new video file. Extract the .rar file using WinRaR 5.x and open the .wmv video file in Windows Media Player or VLC Player.
camerart
Joined Feb 25, 2013
3,847
Here are the codes.
Code:
AllDigital
Dim x As Byte
    initialize_ports
    enable_interrupts
    While x > 0
        send_spi_data 0xff
        WaitMs 200
    Wend
End
On Low Interrupt
    If PIR1.SSPIF Then
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            LATB = SSPBUF
        Endif
    Endif
    SSPCON1.SSPOV = 0
Resume
    x = 1
End Proc
    CMCON = %00000111
    ADCON1 = %00001111
    TRISA = %11000000
    TRISB = 0
    TRISD = 0
End Proc
    TRISC = %00010000
    spi_cs = 1
    SSPSTAT = %01000000
    SSPCON1 = %00100010
    IPR1.SSPIP = 0
    PIE1.SSPIE = 0
End Proc
    TRISC = %00011000
    SSPSTAT = %01000000
    SSPCON1 = %00100100
    PIE1.SSPIE = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
Code:
AllDigital
Dim data As Byte
Dim x As Byte
    initialize_ports
    initialize_qei
    enable_interrupts
    While x > 0
            LATD = CAP2BUFL
            spidatareceived = 0
        Endif
    Wend
End
On Low Interrupt
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            data = SSPBUF
            If data = 0xff Then
                spidatareceived = 1
            Endif
            data = 0
        Endif
        SSPCON.SSPOV = 0
    Endif
Resume
    ANSEL0 = 0
    ANSEL1 = 0
    TRISA = %11011100
    TRISB = 0
    TRISD = 0
End Proc
    x = 1
    spidatareceived = 0
End Proc
    PIE1.SSPIE = 0
    TRISC = %00010100
    spi_cs = 1
    SSPSTAT = %01000000
    SSPCON = %00100010
End Proc
    SSPSTAT = %01000000
    SSPCON = %00100100
    TRISC = %01110100
    IPR1.SSPIP = 0
    PIE1.SSPIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
    POSCNTH = 0
    POSCNTL = 0
    QEICON = %10000000
    QEICON = %10010100
    DFLTCON = 0
    MAXCNTH = %00000100
    MAXCNTL = 0
End Proc
Edit2:
Oops, Sorry.
Hi J2,
I've just received a radio kit, I'v been waiting for, so I'm a little diverted.
I don't use the INDEX of the QEI.
C.
jayanthd
Joined Jul 4, 2015
945
Hi J2,
C.
Please check my previous 2 posts.
Show your exact circuit. Draw it on paper and scan it and post it here as .png or .pdf if you don't have circuit designing software. You can use Proteus demo version to draw circuit and take screenshot of it as demo version doesn't support saving files.
Edit:
I just tested my previous code without INDX pin connection in Proteus and it works fine.
Edit2:
Here is video 8. Working fine without INDX pin connection.
jayanthd
Joined Jul 4, 2015
945
OshonSoft PIC18 Basic Compiler final codes follows.
Code:
AllDigital
Dim x As Byte
    initialize_ports
    enable_interrupts
    While x > 0
        send_spi_data 0xff
        WaitMs 80
    Wend
End
On Low Interrupt
    If PIR1.SSPIF Then
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            LATB = SSPBUF
        Endif
    Endif
    SSPCON1.SSPOV = 0
Resume
    x = 1
End Proc
    CMCON = %00000111
    ADCON1 = %00001111
    TRISA = %11000000
    TRISB = 0
    TRISD = 0
End Proc
    TRISC = %00010000
    spi_cs = 1
    SSPSTAT = %01000000
    SSPCON1 = %00100010
    IPR1.SSPIP = 0
    PIE1.SSPIE = 0
End Proc
    TRISC = %00011000
    SSPSTAT = %01000000
    SSPCON1 = %00100100
    PIE1.SSPIE = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
Code:
AllDigital
Dim data As Byte
Dim x As Byte
    initialize_ports
    initialize_qei
    enable_interrupts
    While x > 0
            LATD = CAP2BUFL
            spidatareceived = 0
        Endif
    Wend
End
On Low Interrupt
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            data = SSPBUF
            If data = 0xff Then
                spidatareceived = 1
            Endif
            data = 0
        Endif
        SSPCON.SSPOV = 0
    Endif
Resume
    ANSEL0 = 0
    ANSEL1 = 0
    TRISA = %11011100
    TRISB = 0
    TRISD = 0
End Proc
    x = 1
    spidatareceived = 0
End Proc
    PIE1.SSPIE = 0
    TRISC = %00010000
    spi_cs = 1
    SSPSTAT = %01000000
    SSPCON = %00100010
End Proc
    SSPSTAT = %01000000
    SSPCON = %00100100
    TRISC = %01110000
    IPR1.SSPIP = 0
    PIE1.SSPIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
    POSCNTH = 0
    POSCNTL = 0
    QEICON = %10000000
    QEICON = %10010100
    DFLTCON = 0
    MAXCNTH = %00000100
    MAXCNTL = 0
End Proc
camerart
Joined Feb 25, 2013
3,847
Hi J2,
If you look at this link: https://forum.allaboutcircuits.com/...l-by-location-pic-in-oshonsoft.148795/page-15
and go to #270, you will see the RECEIVER program and PCB.
We are working on the TRANSMITTER program, where I've used the RECEIVER program and PCB, with the 18LF2520 removed and a 18F4431 connected by wires, which once we have got the CODE working, then I'll finish the TRANSMITTER with both latest PICs on one board.
C.
camerart
Joined Feb 25, 2013
3,847
You can test my codes in post 115 to confirm working on hardware ? You need just Encoder connected to Slave and 8x PORTB Leds on Master.
Hi J2,
To clarify, the internal Quadrature encoder uses the QEA and QEB buttons, which I have connected temporarily for testing on the 18F4431 PIC. The Encoder will be connected in lace of the test buttons for correct application.
With the correct set-up when the two buttons are switched in the quadrature sequence, then CAP2BUFL and CAP2BUFH count accordingly.
Will test you programs tomorrow,
Thanks, C.
jayanthd
Joined Jul 4, 2015
945
@ C,
Are you using both PICs TQFP (QFP) package type ?
I changed package for both PICs to TQFP. Only pin numbers change. PORTx connections are same in all packages.
Here is the new circuit. You can connect like this. INDX pin not used.
