MASTER and SLAVE PICs using SPI in Oshonsoft
camerart
Joined Feb 25, 2013
3,880
MASTER board is named as PIC18F4520. You had earlier mentioned it as PIC18F4620 ?
SMDs are difficult for proto work. Why not use PDIP ICs for protowork ?
Hi J2,
Well spotted, but the spare board I found had an 18F4520, which will work for your purposes.
I have moved to SMDs, as much as possible, so I don't tend to buy PDIP PICs anymore.
C.
jayanthd
Joined Jul 4, 2015
945
Hi J2,
C.
Okay, but I think it will be better to keep a few development board which uses PDIP ICs (sockets) so that hardware testing can be done quickly.
camerart
Joined Feb 25, 2013
3,880
Hi J2,
I've wired them up for SPI, but watch out for errors.
Here's the SLAVE program with some of mine, at the beginning.
Change it as you wish, and I'll test it.
First try to get a hserout TEST.. I tried but failed (I'm a bit circuit weary, which makes errors)
C.
camerart
Joined Feb 25, 2013
3,880
hserout test cannot be done with slave without remapping the UART pins. The UART (TX and RX) pins are shared with SS/CS and SDo pins.
Hi J2,
Yes, they are connected in the way you describe.
Can you use them for a test, then I'll disconnect them.
C.
jayanthd
Joined Jul 4, 2015
945
The UART pins cannot be remapped in PIC18F4431. There is no Peripheral Pin Select (pin mapping) option in that PIC. it is better if you output the Slave's CAP2BUFL data on say PORTD Leds. There is no point of printing Slave's SSPBUF value on Slave's UART or PORTx.
camerart
Joined Feb 25, 2013
3,880
Hi J2,
Ok, but use the empty PORTB instead. As it's only for testing I won't add LEDs, but check with a meter.
C
camerart
Joined Feb 25, 2013
3,880
Hi J2,
C
jayanthd
Joined Jul 4, 2015
945
Here is the Slave code. It outputs CAP2BUFL value to PORTB.
Code:
AllDigital
Dim data As Byte
Dim spidatareceived As Bit
Dim x As Byte
Symbol spi_cs = LATC.6
Symbol spi_cs_direction = TRISC.6
    initialize_ports
    initialize_variables
    initialize_spi_slave
    initialize_qei
    initialize_uart
    enable_interrupts
    While x > 0
        If spidatareceived = 1 Then
            initialize_spi_master
            send_spi_data CAP2BUFL
            LATB = CAP2BUFL
            spidatareceived = 0
        Endif
    Wend
End
On Low Interrupt
    If PIE1.SSPIE = 1 And PIR1.SSPIF = 1 Then
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            data = SSPBUF
            If data = 0xff Then
                spidatareceived = 1
            Endif
            data = 0
        Endif
        SSPCON.SSPOV = 0
    Endif
Resume
Proc initialize_ports()
    ANSEL0 = 0
    ANSEL1 = 0
    TRISA = %11011100
    TRISB = 0
    TRISD = 0
End Proc
Proc initialize_variables()
    x = 1
    spidatareceived = 0
End Proc
Proc initialize_spi_master()
    PIE1.SSPIE = 0
    TRISC = %00010000
    spi_cs = 1
    SSPSTAT = %01000000
    SSPCON = %00100010
End Proc
Proc initialize_spi_slave()
    SSPSTAT = %01000000
    SSPCON = %00100100
    TRISC = %01110000
    IPR1.SSPIP = 0
    PIE1.SSPIE = 1
End Proc
Proc send_spi_data(data As Byte)
    spi_cs = 0
        SSPBUF = data
        While SSPSTAT.BF = 0
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
Proc enable_interrupts()
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
Proc initialize_qei()
    POSCNTH = 0
    POSCNTL = 0
    QEICON = %10000000
    QEICON = %10010100
    DFLTCON = 0
    MAXCNTH = %00000100
    MAXCNTL = 0
End Proc
Proc initialize_uart(baudrate As Word)
    Hseropen baudrate
    WaitMs 100
End Proc
camerart
Joined Feb 25, 2013
3,880
Hi J2,
I added the configs at the beginning, and this at the bottom, is this correct?
______________________________________________________________________
Hseropen 9600 'baudrate<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Hserout "PORTB ", #PORTB, CrLf '<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
WaitMs 100
End Proc
(') = commented out so not in the program.
C.
jayanthd
Joined Jul 4, 2015
945
Hi J2,
C.
The code is wrong.
If you want to print CAP2BUFL or PORTB data on UART then you have to try this.
Code:
AllDigital
Dim data As Byte
Dim x As Byte
    initialize_ports
    initialize_qei
    initialize_uart
    enable_interrupts
    While x > 0
            LATB = CAP2BUFL
            Hserout "PORTB" #PORTB, CrLf
            spidatareceived = 0
        Endif
    Wend
End
On Low Interrupt
        PIR1.SSPIF = 0
        If SSPSTAT.BF Then
            data = SSPBUF
            If data = 0xff Then
                spidatareceived = 1
            Endif
            data = 0
        Endif
        SSPCON.SSPOV = 0
    Endif
Resume
    ANSEL0 = 0
    ANSEL1 = 0
    TRISA = %11011100
    TRISB = 0
    TRISD = 0
End Proc
    x = 1
    spidatareceived = 0
End Proc
    PIE1.SSPIE = 0
    TRISC = %00010000
    spi_cs = 1
    SSPSTAT = %01000000
    SSPCON = %00100010
End Proc
    SSPSTAT = %01000000
    SSPCON = %00100100
    TRISC = %01110000
    IPR1.SSPIP = 0
    PIE1.SSPIE = 1
End Proc
    spi_cs = 0
        SSPBUF = data
        Wend
        SSPSTAT.BF = 0
    spi_cs = 1
End Proc
    INTCON.PEIE = 1
    INTCON.GIEH = 1
    INTCON.GIEL = 1
    INTCON.GIE = 1
End Proc
    POSCNTH = 0
    POSCNTL = 0
    QEICON = %10000000
    QEICON = %10010100
    DFLTCON = 0
    MAXCNTH = %00000100
    MAXCNTL = 0
End Proc
    Hseropen baudrate
    WaitMs 100
End Proc
jayanthd
Joined Jul 4, 2015
945
I know and that is what my code does. I didn't post the master code in my previous post because it was already posted a few posts back and it has not changed.
The Slave code in my previous post prints CAP2BUFL value on PORTB and UART and also send it to Master through hardware SPI.
camerart
Joined Feb 25, 2013
3,880
Hi J2,
Testing CODE at #157in Oshonsoft:
Error: Needs HSEROPEN 9600. added, marked <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Error: See attached:
C.
