Your LEDs might be rated with a typical forward voltage of 2.2V but each LED might be different. Some might be only 2.0V and others might be 2.5V.
If you connect 8 LEDs in series and each has a forward voltage of 2.5V then their total voltage requirement of 20V would make them fairly dim if the current limiting resistor value was calucated for a voltage of 2.2V per LED (17.6V total).
If the LEDs are all 2.0V then they all might burn out.
So maybe you should measure them all, group them and connect an appropriate resistor value to each group.
