estimate how many ampers should provide PSU
Reloadron
Joined Jan 15, 2015
7,970
The only way is to measure the current draw. I am going to guess 50 to 100 mA.
I am going to get onboard with that also. Just remember if you go with a mains powered supply that sans a backup, if you lose power the lockset no workie, workie. A 6.0 volt 1.0 Amp supply would likely be adequate.
Ron
28,460
Certainly a 6 volt dc SUPPLY WITH THE BATTERYS as a backup would work. ADD a N.O. pushbutton to back up the mains powered source if there is a power outage. Not to operate the unlatch, but to power the input during a power failure.
That higher current draw would only be during the actual unlock sequence.
Consider that those AAA sized batteries will mostly be providing a very low current to that non-activated lock circuit, the majority of the time the lock will not be consuming more than a very few milliamps. This is based on the guess that in that product the battery life is intended to be many weeks. The higher current draw will be during the actual time that the lock is being released.
thor21
Joined Sep 29, 2024
435
@Reloadron that psu will be attached on UPS battery backup its okay and still there is option to manually open the door so its fine.
I contacted the manufacturer - they dont know draw.
The reason why i need to know it is to buy a proper Polulu brick ...
So 6V / 1A brick from core 24V (10A) psu is good to go?
