ESR PD, which is mostly if not all USB-C for portable chargers, is all you need. The other end of the cable makes no diff.Right now I have several chargers I can use with phone, power pack, etc. I should not have to buy another charger for some years to come now.
If I am just out buying a charger, then as a consumer I would choose the PD type, because it can charge everything I have, and my cables make no diff. If I use one cable 100x in a week , or 5 cables just 20x per week, the one single cable will fail way sooner than my others, which means into the trash it goes because it gets used too much. Same priciple applies to wall warts, the more they are used (heating cycles) the sooner they fail.
The problem is not how many different cables you have, it's how soon they fail and replaced.
