Hi, Please refer to the schematic attached. This is shown on the motor itself. Please correct me if I am wrong.
I believe the blue must be the active and black the neutral because the capacitor is across these lines. This is unusual because blue is often neutral. I know there are 3 different speeds for this motor. From the schematic at what points on the inductors would you set the active to get high, medium and low speeds? Or perhaps the neutral line has to be moved? Anybody know? Probably a Chinese made motor not having the same conventions as in Australia.
