Aligned Domains in both Dialectic material and Magnets.
Beetle_X
Joined Nov 2, 2012
84
Easiest way to inquire about this subject is, why doesn't a capacitor become magnetized if the domains in the dialectic are aligned the same way as a magnet?
Thank you for your expertise!
It is appreciated!
Ya’akov
Joined Jan 27, 2019
10,368
Dielectric, by the way.
Would you elucidate your comment: "the domains in the dialectic are aligned the same way as a magnet"?
Dielectric materials typically used in capacitors have a magnetic permeability of ~1, with air being diamagnetic, and PTFE being weakly so, but such materials can't be magnetized in any case.
See the list, below.
MaterialRelative Permeability \mu_rNotes
Air~1.0000004Diamagnetic
PTFE (Teflon)~1Weakly diamagnetic
Polypropylene~1
Ceramic (Class I, e.g., C0G/NP0)~1
Barium titanate (Class II)~1High \varepsilon_r, still non-magnetic
Glass~1
Beetle_X
Joined Nov 2, 2012
84
Well I guess that domain alignment is not the only factor. I think I read that free electrons made a difference too. Domain alignment is the most stated cause of magetism but actually is not if you count dialectics. So what makes a Dialectic different? it has domains.
Beetle_X
Joined Nov 2, 2012
84
My own logic was that if a substance could have it' domains arranged to from front to back that it would be magnetic.
28,593
Posts #2 and #3 are both correct, but consider that tose "domains" in a capacitor are ELECTRIC FIELD domanins, not megnetic field domains. AND , know for certain that in afew materials that capacitor charge DOES REMAIN for quite a while.
Ya’akov
Joined Jan 27, 2019
10,368
The only domains that might appear in a dielectric are ferroelectric domains. These are not magnetic, they have no magnetic properties, and they require a ferroelectric material such as the Barium Titanate used in some SMD capacitors.
Ferromagnetic domains have nothing to do with ferroelectric domains.
Ferromagnetic domain: uniform spontaneous magnetization (in a ferromagnetic material)
Ferroelectric domain: uniform spontaneous electrical polarization (in a ferroelectric material)
The only similarity between the two is structural. You should also be aware that a dielectric material in a capacitor does not have to he ferroelectric and so most capacitor have no domains—electric or magnetic—as part of their attributes.
Ya’akov
Joined Jan 27, 2019
10,368
Only way for nascence of magnetic field is electrical charges moving.
Static charges generate electrical field.
This is a very important point. Electrons produce magnetic fields only in motion, in a charged capacitor they are at rest. The magnetic field associated with the charging/discharging of a capacitor is identical to the magnetic field in a wire when current flows. The presence of a dielectric has no effect on it, it is related to conductors.
