@rahulpsharma I think you have too much time on your hands but they also thought Einstein was crazy at first.
Maybe you should take up knitting
A simple dimensional analysis will show that this is wrong: in SI units, mass is measured in kilograms and force in kilogram-meters per square-second (newtons). Another big hint is that mass is a scalar quantity, while force -- which has both magnitude and direction -- is a vector quantity.What does it take to move something or change the movement of something? It takes force.
The amount of force it takes.....is the mass. That's how mass is defined. Usually, we call that force, weight. We have X lbs. of mass. Or kilograms, to be European.
I've corrected you on this before: ellipses are one of the possible solutions to the gravitational equation only for the very particular case of two point-like bodies, an unphysical idealization that only exists in textbooks. Actual orbital dynamics are never elliptical; please stop with this strawman argument.All the gravitation equations are for elliptics.
This is somehow both nonsensical and wrong. Newton's universal law of gravitation presumes perfectly symmetrical (point-like) particles. In relativistic quantum mechanics, the electron is perfectly symmetrical and explicitly affected by gravity.There is another definition of mass. Mass attracts mass. Mass is gravitational. THIS IS NOT TRUE. ONLY UNSYMMETRICAL MASS, ATTRACTS UNSYMMETRICAL MASS. Gravity has no affect on symmetrical particles or symmetric mass. What is UN-symmetrical mass? It's a dipole or an atom.
Wrong. Physics is precisely about using mathematical models to understand natural phenomena. It's been this way since before Newton, and with good reason: without math all we have are stories.Modern science uses math models. Classical science uses physical models.
Your crackpottery was evident a few sentences in.This is usually bout the time I get called a crackpot.
He actually gets a fairly low grade on the index.Your crackpottery was evident a few sentences in.![]()
I'm curious how many of those BR would self-identify with.He actually gets a fairly low grade on the index.He's only a Demi-Crack and needs to up the game.
http://math.ucr.edu/home/baez/crackpot.html
| Thread starter | Similar threads | Forum | Replies | Date |
| T | speculative technology space tubes | Off-Topic | 10 | |
Medical evacuation from space station | General Science, Physics & Math | 7 |
