LtSpice - Inconsistent simulation of identical circuits?
Hypatia's Protege
Joined Mar 1, 2015
3,228
Kind friends.
Please note that the PSU circuit represented in the attached schematic and image files is comprised of two identical circuits connected for 'complementary' (i.e. 'split polarity') output.
My question -- As simulated: |Ek| - |Ea| = 16.887V -- when one would expect |Ek|=|Ea|:confused:
Granted! 1/30'th of 1% isn't much -- even so, one wishes to understand 'the ways of Spice':cool:
Perhaps component tolerance is simulated by default?:confused:
Many advance thanks for any insight/info!:)
Best regards
HP:)
PS -- Re: the attached image -- please note that although the cursors are occulting the traces -- I assure you they are there!:D
jpanhalt
Joined Jan 18, 2008
11,087
Interesting. For 3 runs, I got 2.281 V (0.00306%), 1.24 V, and 0.26 V differences. The latter values were -75.58909 kV and 74.589351 kV. I wonder whether the cursor value is reading pixels on my screen versus the result of a mathematical calculation? If it is actually reading the screen, I am surprised it is that good.
Here is a snippet of the positive voltage with cursor:
And of the negative cursor (magnifications are not identical):
The fine structure of the curves are very slightly different at the maxima. Although, at the normal viewing size, they appear to be identical. At the same time, one voltage's ripple may be increasing and the other decreasing. Measurement on the ripple might not be identical.
Do you get similar results with very high enlargements?
John
OBW0549
Joined Mar 2, 2015
3,566
SPICE does mysterious things like this from time to time. It is also not exact. You might try fiddling with the RELTOL option a bit to see if you can improve results.
No, it does not. SPICE only simulates component tolerances by performing multiple simulation runs, each with different component values according to your tolerance specifications, in a Monte Carlo analysis.
GopherT
Joined Nov 23, 2012
8,009
@Hypatia's Protege
You are looking at a single point in time, 10 mSec after simulation startup. Let it run longer to get to see if the error shrinks. Set starting values of the components instead of letting everything start at 0V. Expecting a stable system in 10 mSec on a 50kV system doesn't happen in real life, why should it happen in a simulation?
Spice uses Monte Carlo methods for simulation...
https://en.wikipedia.org/wiki/Monte_Carlo_method
You should have more precise answers after longer simulation time.
Alec_t
Joined Sep 17, 2013
14,335
There's something that looks like random noise in the waveforms. Easiest to see if you add a behavioural voltage source whose output is the sum of the two waveforms.
MrAl
Joined Jun 17, 2014
11,496
Kind friends.
Best regards
HP:)
Hello there,
It looks like it could be a simple phase delay in the calculation due to the step size.
For example, if we calculate two RC networks by hand for time increments of 0.1 second each, we have to do one before the other and so RC1 gets calculated at t=1.1 and is logged as a solution while RC2 still has it's value of 1.0, the old value. If it is displayed at t=1.1 the values will not be the same until RC2 is calculated if there is a calculation delay, and it is even possible that each network gets calculated at alternate sub steps, which would mean RC1 gets calculated at t=1.05 and RC2 gets calculated at t=1.10 seconds, then the results displayed for each.
Try setting the max step size much smaller like 1e-8 and see if there is a lower error.
It could also be the rounding method used, where they use the alternate random round method for binary values which is believed to produce lower distributed errors over a large number of calculations.
MrAl
Joined Jun 17, 2014
11,496
That does the trick. Here's what the sum looks like when max step = 1e-8 :-
The error is now down at the uV level after a few mS.
Oh yes, very nice :)
I hope it didnt take too long to run with the smaller step size, that's the drawback although set within reason it gives better results simply because all the derivatives are naturally smoother, and wow, there must be a lot of derivatives in this circuit.
I would say that it could indicate a flaw in the adaptive step algorithm they use but then again the original accuracy wasnt that bad either...we just got very picky :)
MrAl
Joined Jun 17, 2014
11,496
Hello again,
Oh that's great, i guess :)
That might mean we could try to simulate one of those chaotic oscillators. I tried one and it didnt act chaotically but i think it was because the simulator was noiseless and a real circuit always has some noise.
I ran into a real life problem one time where the noise was very low so the design did not work because it depended on at least a small amount of noise. I had trouble convincing the designer because it looked good on paper.
KL7AJ
Joined Nov 4, 2008
2,229
Kind friends.
Best regards
HP:)
I also discovered that LT Spice limits the Q of a simple LC tank circuit to a value of 1000. Not that there's any problem with this....other "manifestations" of SPICE will simply spit out a divide by zero error if you have infinite Q. I haven't been able to identify the limiting factor in LTspice....I presume a fixed finite resistance is incorporated into even "perfect" inductors....though this doesn't seem to show up on any of the library inductor properties.
Eric
OBW0549
Joined Mar 2, 2015
3,566
Those noise sources would only be active during a .noise analysis, which is a special form of .ac analysis; they would not show up during a time-domain .tran analysis.
Been there, done that. I once worked on a product in which the clock oscillator for a CPU chip was built from a couple of TTL inverter gates, a crystal resonator, a couple of resistors and a capacitor. Crude but effective; it always started up and worked perfectly.
Until one day when we got a panicked call from Production: CPU cards were all passing their board-level tests, but when assembled into their card racks along with the voltage regulator card and RAM, ROM, ADCs, DACs, etc. they either wouldn't work at all or would mysteriously go several seconds or even minutes after power-up without working, then suddenly start oscillating, after which they worked fine.
The engineer responsible for the CPU card pulled his hair out for several days before finally tracking down the problem: the regulator card, based on a switching regulator, was too quiet! It seems Purchasing had begun buying filter capacitors for the regulator cards from a different manufacturer, and the new capacitors had a much lower ESR than the old ones, as well as much, MUCH lower equivalent series inductance. As a result, the tiny little voltage spikes that were normally on the regulator output were now about one-tenth the amplitude they had been previously.
And unbeknownst to the engineer, his oscillator circuit depended on those spikes to initiate oscillation. No spikes ==> dead CPU!
MrAl
Joined Jun 17, 2014
11,496
Hi again,
Interesting story. It's funny the things that can turn up as time goes by. Time is the greatest tester of them all :)
It's too bad then that LTS doesnt work in time domain for noise analysis, but maybe they have a separate noise source we can put into the circuit? Or maybe they allow a "rand" function in one of the function sources.
That's what i used in the past, but not for LT Spice yet.
LATER:
Ok rand works but will take a little fussing with to get a decent 'noise' signal.
