Hi there, I currently try to design an AD converter as simple as possible (for didactical reasons). It should be able to act as a 3bit converter on a time-dependent signal. It should preferably output a quantised signal (blue) from an analogue input (red)
If possible I only want to use opamps, resistors and (maybe And/Nand gatter). I started with a basic flash converter and feel that if I could sum the outputs of all comparators properly I would get the desired blue curve. Nevertheless my idea to just add an opamp summing amplifier didn't work at all.
Any idea how I could go on from here? I would appreciate any help.
