Thanks. Do you mean my MOSFETs are not high-enough amperage? I thought they were... Anyway this is just a model.You have an erroneous approach. You placed a floating current source on the diagram! And it is not clear how this will be implemented in reality! You may need a voltage source with a current limited to 10 amperes. It can be done. Also you used standard transistors in the circuit which are very weak. What is the meaning of this?
Depends upon what they are supposed to do.Does anyone know if I should keep those diodes by the mosfets?
Thank you! What does that code do exactly? Should I use that power source model from now on?You are acting too free with LTspice!
That's probably what went wrong in that design, yep!
