Low voltage cut-off circuit advise [SOLVED]
12,174
No, i mean why is the output of the first opamp connected directly to the battery? What is this supposed to do for the circuit?
anishkgt
Joined Mar 21, 2017
549
hi,
This is an example of Limit detector using a LM393 comparator.
E
So the hysteresis here shows a time from 0.38s to 0.78s. where the opamp output would pulled LOW. So as the cell recovers wouldn't the opamp switch back ON, at 0.8s?
I was under the impression that the inverting pin would always invert the signal at the output, so wouldn't matter here ? wouldn't it invert a +2v8 to -2v8 ? What does R1, R3 and R6 ? I believe R2 is for hysteresis.
ericgibbs
Joined Jan 29, 2010
21,467
What does R1, R3 and R6 do in the simulation ?
hi,
R2 and R6 are explained in Steps 2 & 3 of the Adding hysteresis PDF, I posted earlier.
R1 is partly used as a current input limit in the event of 'vr' being set to +3.3v.
As the LM393 output is a Open Collector a pull up resistor to +V is required, ie: R3
E
anishkgt
Joined Mar 21, 2017
549
Thank you.
i've managed to extend the hysteresis window of the comparator to 3v8 and followed this tutorial from sparkfun to create a potentiometer.
