The pads marked as + and - are the charge/discharge pads.What is the intent of that battery connection?
So the hysteresis here shows a time from 0.38s to 0.78s. where the opamp output would pulled LOW. So as the cell recovers wouldn't the opamp switch back ON, at 0.8s?hi,
This is an example of Limit detector using a LM393 comparator.
E
Its not connected to the battery its connected to a 6 pin connector.No, i mean why is the output of the first opamp connected directly to the battery? What is this supposed to do for the circuit?
ak
I thought SV1 was a jumper field or dip switch. oops.Its not connected to the battery its connected to a 6 pin connector.
hi,What does R1, R3 and R6 do in the simulation ?
can you please share the simulation file.hi,
E
