Low pass filter (adding resistor parallel with capacitor )
karas
Joined Sep 8, 2011
216
why in low pass filter we sometimes add resistor in parallel with capacitor ( it just doing bleeding and discharge the cap. Or it has another job?)
Thanks,
SamR
Joined Mar 19, 2019
5,542
Ummm... Capacitive reactance? And RC filtering freq? Paralleling a Cap with Re on xstr CE amp to increase gain?
LvW
Joined Jun 13, 2013
2,038
Thanks,
Yes - the "job" depends on the particular circuit.
That means: A general answer cannot be given.
Example: A damped opamp-based integrator is a first-order lowpass circuit.
In this configuration the parallel R is necessary to avoid saturation of the opamp (which needs a resistive negative feedback).
35,233
Sir may i have your email? i wanna have a cooperation with you.
Personal email addresses are not shared on AAC forums.
If you wish to communicate with a member use PM (personal message). Click on the member's name or avatar (screen icon) and "Start a Conversation".
nextofyourpcb
Joined Aug 6, 2019
32
OK thanks for your help. But i can see anything at their profile.
I didn't see the button of "Start a Conversation".
bertus
Joined Apr 5, 2008
23,013
New members can not initiate a conversation until they reach 10 posts.
A senior member can initiate a conversation with a new member.
The new member can reply to that.
Bertus
