Looking for specific switch
fanno15
Joined Dec 7, 2017
6
Hi
I need a single pole double throw centre open switch that will be changing between 3V, off and 25V. Can anyone recommend such a thing? Thanks
in advance!
MaxHeadRoom
Joined Jul 18, 2013
30,658
There are several simple SPDT centre off switches from toggle to rotary to chose from..
Are you looking for something special?
Max.
fanno15
Joined Dec 7, 2017
6
No nothing special, I was just kind of overwhelmed by the number of options and thought someone here might have a say. It just needs to be a simple switch. Preferably toggle, but not necessary.
Nathan
SgtWookie
Joined Jul 17, 2007
22,230
It would also help to say what your source of 25v and 3v are/is.
Will you be switching between the outputs of 2 power supplies?
Or do you want to use the switch to select between two different voltages being output from a single voltage regulator?
Or do you have some other idea?
