Looking for GAL/PAL?CPLD programmer
eda8048
Joined May 16, 2021
7
I'm going to start playing with some GAL's I have an will be needing a programmer. I'd be looking for one with a USB interface that works with Windows 10, and supports a wide array of devices. While I'm starting with basic GALs, I'd expect I'd move on to more complicated devices.
Any advice on programmer models would be greatly appreciated !
Deleted member 115935
Joined Dec 31, 1969
So GALs are OLD
great things, a specific companies version of PAL's
But being old, they are going to be hard to find a programmer for ,
by hard probably expensive,
PALs and such like now days are coded in an RTL language such as VHDL or Verilog,
They used to be programmed in long dead languages such as ABLE,
your going to have find finding tools that support the GAL and the RTL language,
Even if you d find a program, will it run on W10 ?
If you go for something like a small FPGA, then they have sw and tools, and are programmed via cheap JTAG programmers in board.
In conclusion,
GALs are a dead end to work with to learn, and not relevant to the real world.
Lo_volt
Joined Apr 3, 2014
376
Agreed!
Learning about GALs might be useful if you are looking to repair or modify old device that uses them. Otherwise move on to FPGA's. Altera and Xilinx are two large manufacturers of FPGAs. They both make development boards that designers can use to learn about their parts as well as their development platforms. Some of these development boards are very low cost and come in familiar footprints such as Arduino, etc.
CPLDs are programmable devices that are still in use and are another option. CPLDs generally aren't as dense as FPGAs but they have the advantage of not needing a separate ROM to hold the device configuration. On power up they are ready to go. An FPGA needs some time to load its configuration before it can operate.
Ian Rogers
Joined Dec 12, 2012
1,136
Straight into FPGA is a daunting task... I program small GAL's... Still available from Microchip 22v10 and 16v8
I use winCUPL to program and I use the good 'ol TL866II to burn them...
winCUPL is XP software but I still use it on win10 "couple o' bugs" but does the job.. Microchip have adopted the software..
eda8048
Joined May 16, 2021
7
I have a lot of unused surplus PALs/GALs, and am unlikely to use any knowledge gained in my career. I'm looking for hobbyist friendly parts, DIPs or SOICs, or very small modules. In looking to build some projects I'd have to weigh the cost of a new part versus a part I have already - in DIP package.
I like the idea of In System Prrogrammability - but is that available in a DIP package or small module costing ~$3 ? I see PAL/GAL programmers on ebay for $100 ... but many do not mentions Windows 10.
I was just reading about the AFT750 Atmel/Microchip parts ... some in DIP package.
Thanks for the advice !
eda8048
Joined May 16, 2021
7
I have nearly nearly 500 pieces of PALCE 22V10H-15 and PALCE29MA16H-25 in 24 pin DIP package. I'd like something to program them.
Joined Dec 31, 1969
Have you tried selling them ?
especially if they are still in packaging.
Lo_volt
Joined Apr 3, 2014
376
There are board repair services that are looking for IC's like these. They are cute and might be fun to play with for a short while but the 29MA16 has 16 macrocells and the 22V10 only 10. That barely gets you a decent binary counter. Given that tools to program these are hard to find and seriously rudimentary, I don't see much value in them. As I said at the start there are people looking for these parts who can get far more value from them than you.
I'll say it again, the contemporary tools are far more advanced than those that came with those parts when they first came out. Vendors now allow VHDL or Verilog coding as well as design via schematic. The parts that I've experimented with allow you to create a microcontroller core and program it in c. There are so many more options available today that it doesn't make sense to bother with those ancient parts.
See the Cypress PSOC Pioneer kit (under $30) here:
https://www.cypress.com/documentation/development-kitsboards/cy8ckit-042-psoc-4-pioneer-kit
It allows direct connection to your PC via USB, an easy to learn development environment and tutorials that get you off the ground quickly. It also comes in the Arduino footprint so that you can use Arduino shields if you want. There are board in different form factors that are lower cost as well.
Joined Dec 31, 1969
the PALCE 22V10H-15 are going for 10 quid each in the UK ebay .
Lo_volt
Joined Apr 3, 2014
376
For an interesting history on programmable logic, this interview is a good read:
https://archive.computerhistory.org/resources/access/text/2013/05/102702200-05-01-acc.pdf
It's an interview with the designers of Signetics' first programmable parts, what they called Field Programmable Logic Arrays (FPLA). In this day and age, programmable logic is very much taken for granted, but these guys came up with the concept and brought it to fruition as a product. True innovation. I'm in awe of how far we've come.
eda8048
Joined May 16, 2021
7
So GALs are OLD
In conclusion,
GALs don’t require using a hardware synthesis language like VHDL or Verilog, or any other special design tools.
GAL equations are authored in a plain text file, using a format called EQN, and are then converted to a binary format called JEDCOM, or JED, which contains the fuse data.
Joined Dec 31, 1969
As I said,
very old technology
The later tools do allow you to program them in an RTL,
but as you say, the majority ( if not all ) of the PAL / GAL / CPLD / PLD /
are so simple they allow you to drop back to program in the basics of the structure,
Not that anyone would do .
dcbingaman
Joined Jun 30, 2021
1,065
Recommend an FPGA module. These range from $6 bucks and up. Thousands of times more powerful than PAL's GAL's. An FPGA module can be plugged into a breadboard for prototyping or plugged into a PCB for final project. I personally like Xilinx Artix-7 Digilent CMOD A7 FPGA module, but it does cost $89. Here is an entire list you can buy from digikey:
https://www.digikey.com/en/products/filter/evaluation-boards-embedded-complex-logic-fpga-cpld/796?s=N4IgjCBcoLQExVAYygFwE4FcCmAaEA9lANogCsIAugL7X4BsiIAlgCZQgxgAME+ADqg4h8qAJ79sHAIYBnFLSA
Every manufacturer has its own free programming tools that can work on Windows or Linux along with online lessons etc. I doubt anyone is using PAL's and GAL's anymore, just like we no longer use 7400 logic chips. You can use Verilog or VHDL and some tools allow you to create a digital schematic. In our modern times, I think it pays to learn Verilog or VHDL or both.
GT_1
Joined Oct 9, 2020
7
Responding to comment(s) about hard to find and expensive....
Many listings on ebay...e.g. a complete experimenters kit purports support for over 15 devices, accommodates virtually any dip
TL866II Plus programmer TL866 nand flash AVR PIC Bios USB Programmer + adapter | eBay
Also last I saw Lattice still sells a few, and had verilog programming support, but that 10 yrs since I looked
someone below said microchip makes them
16v9 and 22v10 very easy to find on ebay - sometimes even the smallest FPGA is overkill and requires jtag so still a place for these old devices when all you need is a half dozen gates and a couple flops.
GT_1
Joined Oct 9, 2020
7
Many listings on ebay...e.g. a complete experimenters kit purports support for over 15k devices, accommodates virtually any dip
16v8 and 22v10 very easy to find on ebay - sometimes even the smallest FPGA is overkill and requires jtag so still a place for these old devices when all you need is a half dozen gates and a couple flops.
update: it looks like lattice still has dev support for them and a directory of vendors that sell. Also, I am assuming this is just sor some quicky hobbyist bench hacking - I would not recommend for any production. NXP has some small configurable gate IC's and Silego, now part of Dialog Semi has some ultra tiny analog/digital FPGA's.
Joined Dec 31, 1969
Just to note,
the "simple" programmers you highlight, such as the Ti one,
do not necessarily interface to the tools to program the GAL / PAL
or dont support the protocol needed,
JED file is great, but it does not tell the programmer what voltages or timings needed for the specific device.
