Looking for a Recommendation for a Multimeter that can Measure the Peak Current of a Square Wave
Zohar
Joined Nov 19, 2015
70
Hi
If you try to do Current measurement on a square wave, in order to find the current in the "1" part of the wave,
most multimeters will not give you that info, when you set them on Current measurement mode.
You will probably get some effective value, instead of the value at the peak of the wave.
Can anyone please recommend me a multimeter that can do it?
For example,
If you have an IR Remote Control for some device (TV, TV Box, Audio System, etc),
and you want to know the current going thru the IR LED.. which receives a square wave.
Thank you
Zohar
Joined Nov 19, 2015
70
Thank you very much nsaspook.
Fluke's Multimeters are quite expensive,
maybe you know one that is not by Fluke, and should do it too?
Zohar
Joined Nov 19, 2015
70
Thank you both.
If taking the example of an IR Remote Control, then we're talking about 38KHz..
The USB Adapter will not be good since it's samples at 1ms intervals.
Zohar
Joined Nov 19, 2015
70
Thank you.
BTW, in general, a Multimeter that has a Min/MAX feature should do the job?
I should just set it to Current measurement, choose "Max",
and then measure the current when a wave is passing, and then get the value of the "1"?
Measurements like this are usually dependent on "crest factor".
The current ranges on most multimeters are just resistors. This may be troublesome without an I-V converter.
Frequency response is another issue.
Zohar
Joined Nov 19, 2015
70
I see.
I have my eyes on Uni-T - UT139C.
It looks like a nice Multuimeter, it has the Min-Max feature,
and it's priced reasonably.. (even more than reasonably) - it's around 40$.
Will it's Min-Max feature be relevant for a 38KHz wave?
Here's its product page:
http://www.uni-trend.com/html/product/General_Meters/Digital_Multimeters/UT139/UT139C.html
Its manual is under the "Docs & Software" tab,
I downloaded it but couldn't see any mentioning for a Frequency regarding Min-Max.
Maybe you know how can I find this info - if this Multimeter is relevant for what I need?
BR-549
Joined Sep 22, 2013
4,928
Zohar, I have never seen a multimeter designed to measure square waves. danadak has the solution....a pocket scope.
wayneh
Joined Sep 9, 2010
18,096
I'd just use the poor man's version: Measure the current with a cheap meter and multiply by two. You did say it's a square wave. I believe a cheap meter simply reads the time-averaged current. If you didn't really mean square wave and instead have some sort of PWM, that's different. You could set the PWM to 100% and measure the peak current directly.
Zohar
Joined Nov 19, 2015
70
It's an IR Transmission..
o definitely not a square wave that we know its duty-cycle and can calculate anything about it.
OK, I will use a scope..
jpanhalt
Joined Jan 18, 2008
11,087
Here are the footnotes to the AC Current measurement for that meter:
That is on pages 20-21 f the user's manual. I am not sure min/max has the same meaning as peak to peak for all meters. It can mean, the minimum and maximum voltages over a fairly long period, as is often needed in measuring temperature.
