Yes, but you'll need to describeHi,
I met many times that forget shut down my device which run out of electricity, are there any modules can automatic shutdown circuit when not used for a long time.
Thanks
Adam
Thank you MrSalts.Yes, but you'll need to describe
- what device you have,
- what amount of time
- your definition of "shut down" (how many mA of current is acceptable.
- how will you restart it?
Yes,Thank you MrSalts.
just diy parts, like a small Arduino car, LED display etc. they used a batteries bank as power supply, some times forgot to turn off and the battery is exhausted.
are there any modules can auto shut down it when not in using a while?
That method works well. Just make sure to use appropriate logic-level mosfets.Hi, I am testing this one:
https://circuitjournal.com/arduino-auto-power-off
for example, I have a multi meter which can auto power off after few minutes of last use.Do You want to turn-off an Arduino,
or do You want to use an Arduino to turn-off some other device ?
Thanks.That method works well. Just make sure to use appropriate logic-level mosfets.
Thank you ericgibbs.
