looking for a module of Automatic shutdown circuit when not used for a long time
LAOADAM
Joined Nov 21, 2018
956
I met many times that forget shut down my device which run out of electricity, are there any modules can automatic shutdown circuit when not used for a long time.
Adam
MrSalts
Joined Apr 2, 2020
2,767
Adam
Yes, but you'll need to describe
- what device you have,
- what amount of time
- your definition of "shut down" (how many mA of current is acceptable.
- how will you restart it?
LAOADAM
Joined Nov 21, 2018
956
Thank you MrSalts.
just diy parts, like a small Arduino car, LED display etc. they used a batteries bank as power supply, some times forgot to turn off and the battery is exhausted.
are there any modules can auto shut down it when not in using a while?
MrSalts
Joined Apr 2, 2020
2,767
Thank you MrSalts.
Yes,
Arduino car? What is this?
How is the display connected?
how do you want to restart it (push button or other?
Do you have free pins on the Arduino? Which ones?
is the display powered by the Arduino or other?
Which Arduino 3.3 or 5v.
It is very possible to do what you want but detailed answers are needed.
LAOADAM
Joined Nov 21, 2018
956
Do You want to turn-off an Arduino,
or do You want to use an Arduino to turn-off some other device ?
for example, I have a multi meter which can auto power off after few minutes of last use.
If I diy that multi meter, I need a auto power off.
