Thanks for your insights RB,
Standard aquarium pumps are way too strong. The amounts that are being dosed are way too small to depend on an aquarium pump. For instance with my aquarium the amount of calcium solution dosed per/hr is roughly 2mL.
I have looked into other options such as diaphragm pumps but then you have to worry about internal parts touching and calcium build up. In the end I looked at what all companies are using for their consumer available dosers and all of them are peristaltic.
My thoughts here are this, if the user sets up their pump as it would be used and runs a series of (10-20) test runs using the exact liquid and measures they need in their tank, then measure each of those amounts and average them, they should get a pretty good idea as to how much each pump is dosing. Granted this may need to be done every 3-6 months, but that would be considered maintenance.
Also, it is important to use a high purity tygon tubing as its specifically designed for peristaltic dosers. Its more flexible and regardless it maintains it original form for quite some time.
