First time posting. Hope this is the correct spot for this question. I have a piece of equipment that connects to a floor scale, which is not working. I have a similar replacement but the wire colors don't match up and the wires are sealed in the load cell. I took ohm readings (see attached) and figured out most of it, however, I'm not sure how to determine (+/-) between white and black on scale 1 vs white and yellow on scale 2. Appreciate any help you all can provide. Thank you!
