LM741 Op Amp not working
Audioguru again
Joined Oct 21, 2019
6,826
Your 1k resistors R1 and R4 do not split the 15V well enough.
A second opamp (use a dual 1458 for both) can be a follower with two 10k resistors biasing the +input at +7.5V then its +7.5V output can be a low impedance for the phantom ground.
sghioto
Joined Dec 31, 2017
8,751
Granted a dual op amp would be better. The design is to show that the circuit the TS was trying to achieve using a LM741 with a single supply is feasible. The 1K resistors are fine.
AnalogKid
Joined Aug 1, 2013
12,268
Interesting that TI's LM358 has a common mode voltage that goes down to Vee, but On-Semi's LM358 has a common mode voltage that extends to -0.3V.
So, in theory, an inverting amplifier with the non-inverting input connected to ground should work.
No theory needed - been doing this since the 70's.
ak
