LM317 voltage regulator circuit
notoriusjt2
Joined Feb 4, 2010
209
allright. I pulled up the LM317 spec sheet and found the following
so....here is the work I have based on this equation
I am wayyyyy off base here. what am I doing wrong?
t_n_k
Joined Mar 6, 2009
5,455
The adjustment pin current is typically a max of ~5uA for the LM317. You appear to have Iadj = 0.01A - which is way off.
Wendy
Joined Mar 24, 2008
23,816
In R2 of your schematic (your diagram and the application notes have reversed designations) you have 100Ω. Since the method the LM317 uses is to maintain 1.25V between the output pin and adjust you should be able to figure current. The current through R2 is the same as through R1. From there it is gravy.
Jony130
Joined Feb 17, 2009
5,600
Iadj is 50uA typical, and 100uA=0.0001A max.
But this circuit can be treat as a voltage divider.
Since R2 = 100Ω and voltage across R2 is equal 1.25V we have
IR1 = 1.25V/100Ω = 12.5mA
And the current that is flow through R1 is equal
IR2 = Iadj + IR1 = 12.6mA
And we want Vo = 15V----> VR1 = 15V - 1.25V = 13.75V
R1 = 13.75V/12.6mA = 1.09126984KΩ
\(R1=R2*\frac{Vout-1.25V }{1.25V+I_{ADJ}*R2}\)
Or
\(R1=R2*(\frac{Vout }{1.25V}-1)\)
Kermit2
Joined Feb 5, 2010
4,159
The position of R2 and R1 are different in your problem and in the example you posted. Go back a redo the math and notice carefully how the fraction made by the resistor values is arranged in the example and how the Resistors in the problem are the reverse.
t_n_k
Joined Mar 6, 2009
5,455
Agreed - I misread the data sheet. Looked at the adjustment pin current change row rather than the actual value. I can only put it down to deteriorating vision.
Apologies for the misinformation.
notoriusjt2
Joined Feb 4, 2010
209
\(R1=R2*\frac{Uwy-1.25V }{1.25V+I_{ADJ}*R2}\)
Or
\(R1=R2*(\frac{Uwy }{1.25V}-1)\)
what is the variable "Uwy" referring to?
notoriusjt2
Joined Feb 4, 2010
209
thats a great explanation.
I = 0.0125A
R = 13.75/0.0125 = 1100
which is basically the same answer that was derived by Jony130
however, this answer was listed as wrong
what are we doing wrong here?
notoriusjt2
Joined Feb 4, 2010
209
per wikipedia
"In electronics, the dropout voltage of a voltage regulator is the smallest possible difference between the input voltage and output voltage to remain inside the regulator's intended operating range."
so if I understand correctly the dropout voltage has no effect on what the output voltage will be.
bertus
Joined Apr 5, 2008
23,005
Rwn and Rpn are the resistances of the wires from the regulator to the load.
These will be dependend on the used wire, but can be dismissed when using small loads, as the values are mosttimes very small.
notoriusjt2
Joined Feb 4, 2010
209
allright so in the equation they are subtracting (IL*Rwp), which in reality is the voltage drop of the wire. since this loss is negligible we will disregard it.
R2 should be -88
also incorrect
