Greetings all; I've been lurking forever but never had a question that wasn't answered in a previous thread.
I've put together the basic LM317 circuit from the datasheet. The only difference is that I have 1 uF caps for both the input and output filters (didn't have any 0.1 uF on hand). At this point I've tried a second LM317, with the same result. I've also tried 100 ohm and 220 ohm values for R1, just in case. The pot I'm using for R2 checks out, a couple ohm at one end, 2.3 kohm at the other. It's on a breadboard, and I've moved all the components in case it was a short.
At output I'm getting almost exactly 1.0V (fluctuating between about 0.98 and 1.00 V). I'm assuming that's because my hacked-together power supply (just a bridge rectifier) fluctuates between about 11.4 and 11.9 VDC. Sweeping the pot has no effect on the output voltage. Replacing the pot with a fixed resistor has no effect, no matter what the value of the resistor is.
Is this a known failure mode for the LM317? I kind of doubt I got two bad ones right off the bat (they were both new), and I don't have a local source for components, so I'd rather not order more until other explanations have been eliminated.
Thanks in advance for any suggestions.
