LM317 current source simulation
Kevil
Joined Jun 28, 2020
224
The circuit in the picture with LM317 should provide 1A current, but it gives only 266 mA. What am I doing wrong? I have also attached LM317.asy and LM317.sub downloaded from the link.
How do I add the name "LM317" to the component image?
38,806
As Eric noted, you are trying to violate Ohm's law.
The LM317 also requires a least 3V across it for regulation so V1 should be at ≥14V.
You can edit the .asy file or add as text from the Edit dropdown.
Below is the .asy file with the designation included.
Edit: Added the .sub file.
38,806
Below is the sim showing the relation between the input and output voltages:
The output reaches 1A at about 14V input.
Note that your file was missing a ground reference, which is required for a proper LTspice simulation.
