LM317 CC CV Problem
yotamamit
Joined Nov 8, 2017
12
Went back to test couple of 317s for CC mode, and nada. No regulation. So its eitherI got three dodgy parts, parts with their pins swapped or just complete fake...needs more testing
dl324
Joined Mar 30, 2015
18,476
Where did you purchase the parts?
If you purchased from a reputable source, it's unlikely that they were counterfeit or defective. Post a clearly focused picture so we can see the markings and surface texture.
yotamamit
Joined Nov 8, 2017
12
When I'll get to it I'll post some pics. They're all from Tayda. I got five, one is being used as the CV and works perfectly.
38,856
That was what I was thinking until this stuff happened
I'm saying that if there's not a voltage drop across the resistor, then the 200mA cannot be going through the resistor.
Thus there has to be an error in your wiring (unless there's a short between the LM317 input and the ADJ pin).
