lm3080 transducence amplifier alternative
Tony Elliott
Joined May 8, 2015
160
Hello, I am trying to make a triangle to sine converter at high speed video frequencies. As you can see in the attachment the lm3080 operational transducer amplifier is at (audio frequencies) I need to replace with a wide bandwidth chip for faster video frequencies. Are there any alternatives? For example if you look at a TL072 compared with a LM6172 you can see the difference in bandwidth.
I will also change the circuits values but for now all I need is a chip alternative, thank you:)06A3138E-BB21-48C4-9356-3325AB738FFA.jpeg
Papabravo
Joined Feb 24, 2006
22,082
This is not the kind of part you want to put on a vero board. suggest you investigate "dead-bug" methods on double sided copper boards. I told you: "you'll shoot yer eye out"
