Unbelievably low distortion amplifier
Ian0
Joined Aug 7, 2020
13,311
@crutschow (and @rpschultz as it was mentioned on your thread). I've now fully recovered after a week in hospital with a bacterial lung infection and after four weeks of antibiotics, I have 82 test results that prove I'm OK now.
So as I now have access to my computer which runs SPICE, here is, as promised, the amplifier that SPICE claims manages 3ppm (-111dB) third harmonic distortion. There are two circuits, almost identical except for the VAS stage, all with very similar figures for each harmonic, but SPICE says that TOTAL harmonic distortion is four times as good for one as the other.
And as I said previously, I really don't see how either of these circuit could possible be as good as it thinks they can.NPNVASresults.pngNPNVASSchematic.pngNPNVASSPectrum.pngMOSVASresults.pngMOSVASSchematic.pngMOSVASSpectrum.png
Ian0
Joined Aug 7, 2020
13,311
Only 1 diode to account for 2 Vbe? I think this is a mistake rather than planned.
The circuit was designed like that, mainly to see what the distortion would be in pure class-b with that circuit. The figures on the FFT were rather a surprise.
38,932
I did the top simulation and it would appear the feedback loop is fast enough to cancel the crossover distortion.
Even shorting out D1 still gives very low distortion.
I agree that the simulated distortion values seem to be too low to be believable.
Ian0
Joined Aug 7, 2020
13,311
I couldn't measure anything that low if I tried. I don't have a signal generator that good! I have a friend who has an Audio Precision analyser but I don't that that can manage below 10ppm, and power supply noise will take over before it gets to that.
28,522
A partial explanation for the low noise level may be that most simulator components are "perfect" and noise free. I offer that as a possible explanation.
Ian0
Joined Aug 7, 2020
13,311
Noise isn't the answer - the FFT shows the harmonics, mainly at around 111dB below the signal, with the noise floor lower. In a real amplifier at 3ppm, the harmonics would have disappeared below the noise floor.
From changing components at random, the Voltage amplifier stage seems to make the most difference, and I would guess that some of the MOSFET models were designed to simulate switching rather than linear operation and are probably too simple, and therefore too linear.
du00000001
Joined Nov 10, 2020
201
Yep. The spice models may cover 1st order "dirt effects" but nothing beyond that. (Some models do not even cover these effects.) For audio circuits you just cannot avoid building them.
Parkera
Joined May 3, 2016
138
When LTspice performs a harmonic analysis, it performs only that. It does not ADD noise to arrive at its number. There is a separate noise analysis if you are interested in the noise levels of a circuit.
LTspice (and I imagine all circuit simulators) base their calculations on the models of the components used. The accuracy of the simulation is dependent on the accuracy of the model. Some models can be very accurate (most bipolar models have the potential to be very good if the manufacture takes advantage of EVERY element). Other models, typically MOSFET power devices, are designed for switching application modeling and are not very accurate beyond 1st order analog.
I suspect the modeled bipolar circuit is correct as far as it goes, and as Ian0 speculates, the MOSFET models are designed for switching analysis, thereby probably giving an overly optimistic THD.
An interesting exercise would be to perform an FFT, not at 1 kHz, but at a much lower frequency, say 20 Hz. Eliminate C2 to take it out of the equation. There C7 will have a large effect on the amount of feedback the circuit sees at 20 Hz. That can give an indication how much feedback is lowering the distortion.
Lowering the gain of the voltage amplifier (a resistor between collectors of Q6a,b) can give insight if that is the primary reason for low distortion.
I really do have to spend some time getting LTspice to work on my new computer.
