Lm2719 chip
Aidan seefeldt
Joined Mar 26, 2023
I’m trying to make a rpm tachometer. Using the lm2917 ic and I’m looking at the data sheet and it says to connect pins 1 and 11 to the negative and positive of the Schmitt comparator, do I need that circuit if I’m using a Hal sensor that would already output a square wave? If not what do I do?
LowQCab
Joined Nov 6, 2012
5,101
It depends on the performance of your Hall-Sensor
and it's particular interactions with what ever it is sensing.
There is also "Noise" to be considered,
if the Hall-Sensor is remote mounted,
or in a very "Noisy" environment, like on an Engine, or a Brushed-Motor.
The Schmitt-Comparitor is never a bad idea,
it's good to have a sharp, well defined, low-Impedance, Square-Wave-Input.
DickCappels
Joined Aug 21, 2008
10,661
Unless there is something really strange in your circuit, it should not hurt anything to use the Schmitt trigger input, plus it will assure clean operation (within limits).
