LM2596T-3.3 and negative voltage
mos_6502
Joined Dec 11, 2017
84
Hi to all,
I'm using a LT1033 for obtain -3.3V from -12V of an ATX PowerSupply.
It works well but the LT1033 heats up a lot.
I had then thought of using a different method, with a LM2596T-3.3, which should provide the maximum possible current (3A nominal) but I can't find any circuits capable of using it to create a negative voltage from a positive one.
Do you think it's a good solution?
What voltage should I power the LM2596T-3.3?
And finally... do you have any circuits to suggest to me to be able to do this?
Thanks everyone!
ronsimpson
Joined Oct 7, 2019
4,829
I have used this part as a simple buck and can get near 3A from it.
I have not tried to get much current out of it in the Inverting mode.
I think your LM2596-3.3 will also work in this mode.
SPICE might not be happy with the circuit. If it does not start, try adding a diode across Cout so Vout does not go above Ground.
mos_6502
Joined Dec 11, 2017
84
Thanks for your reply.
I tried it and now it works, although I get a slightly different voltage (about -3.6 volts instead of -3.3 volts):
How can I instead understand with the simulator how much current it will provide?
