I've created a multiple rail supply using LM2596Ts. I used a combination of the datasheet and internet searching to check viability and it seems that this should be possible.
The max draw of the 5V rail is 700mA and the +/-12V rails is 900mA.
I am finding that there is a noticeable whistle coming from the 5V area of the board, presumably the inductor. It's around 5.2kHz and with lots of harmonics.
The switching frequency should be 150kHz so miles from 5kHz. Max load is 3A so miles from 700mA.
I haven't been able to achieve the exact layout recommendations of the datasheet due to essential locations of other components (see the massive switch in the way!), but the components are close and use thick traces and planes.
The whistle is physically audible on the board and also audible from the audio output (the board also has audio path traces on it).
The component values were chosen via the various tables and graphs in the datasheet.
I tried switching the 68uH inductor for 100uH out of curiosity, but it still sounded the same to me.
Interestingly when using the the TI designer for the LM2596, it produces radically different results to the datasheet calculations.
I measured the nodes using Audacity and a picoscope. Interestingly there is some difference in the results, although this may be to do with the FFT settings.
I would appreciate any help or advice with diagnosing the problem.
many thanks.
many thanks.
