LM2596S-3.3 Voltage Regulator
Rensieboy223
Joined Feb 3, 2024
88
Hi guys,
I want to custom intergrate a the LM2596S-3.3 Fixed voltage regulator in my circuit.
Does everything look OK in my circuit, its for powering sensors so the powersupply need to be stable and low noise:
The Capacitors are all Tantalum.
Thanks already!
ericgibbs
Joined Jan 29, 2010
21,643
That plot shows the initial inrush of current/wattage at power up.
If you look at the plot after that start up period, the dissipation is approx 190mWatts.
Remember, this is a SMPS LM2596 IC, so there will be switching spikes.
What is the specification of your sensors?
E
Rensieboy223
Joined Feb 3, 2024
88
Switching supplies tend to be noisy.
How "low noise" do you need?
That simulates the load of your sensors.
Yeah that's something I don't really know yet, but lower noise seems better for my temperature sensors.
Are the better options than switching supplies, I read that linear supplies generate a lot of heat?
ericgibbs
Joined Jan 29, 2010
21,643
Hi R,
Linear regulators can run hot.
If you used a 3.3Vreg at 1amp from a12V supply, that would 12V-3.3V= 8.7V *1amp = ~9 Watts
E
BobTPH
Joined Jun 5, 2013
11,678
Have you identified a problem with noise or are you guessing that there might be?
A temperature sensor will be working at a frequency ridiculously lower than the noise from an SMPS. Problems are more likely when the frequencies are closer to each other. I would expect that the board already has filtering for higher frequencies.
Rensieboy223
Joined Feb 3, 2024
88
I'm really carefull with the noise and want to minimize as much as possible, in the past I've used the MAX6675 sensor who was even more sensetive for the noise, that was really a big drama so that's why I want to minimize as much as possible.
This is also my building my own complete PLC so I want to make sure I do the right thing.
