LM2596S-3.3 Voltage Regulator
schmitt trigger
Joined Jul 12, 2010
2,229
Yeah I think I just have to try it out, are there any more common options for reducing the overall noise from my Voltage regulator or is a LC-Low noise filter the only option?
As others have pointed out, you follow the LC filter with a linear low dropout regulator.
To minimize the heat dissipation on the LDO, you require the adjustable version of the switchmode regulator, to set its output to the LDO’s dropout voltage, typically 1/2 volt higher than the output.
