I know! I did try many times to have someone do A/B blind test for me, to prove that i am wrong, but no luck! No one seriously wanna do this such test! And they keep telling same things on and on.I'll tell you a secret, you can't argue with objective measurements. If they are claiming to know by "hearing a difference", which is entirely subjective, what good would measurement of millivolts do?
I sold high end audio gear for several years. Not the nonsense stuff but things that actually improved the sound. The way i "proved" things worked or didn't was A/B testing, and if you really think you can get to them at all (which I doubt) it will be with a blind A/B listening test. When they can't reliably pick the "better" one, they might relent, but don't count on it.
Eventually, it will be because there is a non-believer in the room, like with psychics. You are trying to argue science against religion, it's fruitless.
Maybe if i’m keep trying to convince someone do the A/B testing, i’ll let you guys know the results.
Best thanks to all your responses!
