lighting circuit with over ride retractable switch that will reset upon photocell deactivation
littleluke14
Joined Aug 15, 2018
Hi all after some help on the design of a 230v circuit
We have some external lights, that need to be over ridden by a retractable switch. The retractable switch needs to be able to turn the lights on or off at any time, but will reset regardless up on photocell deactivation
The circuit photocell will allow the lights to come at dusk, all the way until dawn
littleluke14
Joined Aug 15, 2018
Thanks for your help, Dave.
Is what I asked at the beginning even possible? As it is what the client is after..
An over ride that will cut out when its day... seems impossible
Dodgydave
Joined Jun 22, 2012
11,395
Yes it's possible, the pneumatic switch uses a mechanical spring to relase it, so during the day( lights would be off) if you pressed the switch it will short out the photocell output and put the lights on for a set period upto 10mins (adjusted by spring tension) then turn off. If you use a Nema photocell the switch is wired across the Live in and Live out terminals.
